... Going from straight'ish bars to H-bars'll put the hose exiting from the master cylinder into a bit of an overly exposed looking position: In that the hose exiting the master cylinder is pretty much the first thing that'll impact with the ground if I crash ([i]when[/i] *cough cough* :wink:).
So ... as I've got to rebuild the brake lines anyway as the nice tidy job I did on the current build is way too short to use with the sweep of the H-bars, I'm wondering about replacing the 8mm straight connector with a banjo fitting - so the hose exits at 90' to the master cylinder, rather than inline with it.
Before I order the stuff in, has anyone tried it, and did it work. I kinda can't see why it [i]won't[/i] work, other than perhaps the length of tap exiting the master cylinder might challenge me to find a long enough hollow bolt?
A drawing might help if this makes no sense as a narrative.
I'll work on this and post something once my fantastic computer graphics skills have been put to the test.
It works fine on my older 6 mm hose brakes - you need the banjo, the banjo bolt and a couple of copper washers. Just the standard parts from the caliper end
http://www.chainreactioncycles.com/Models.aspx?ModelID=3257
