Hope M4 sticky pist...
[Closed] Hope M4 sticky pistons
Have a set on my bike I use for uplifts,so not used every week but without fail every time I go to check it before an uplift some of the pistons are sticking. I manage to release them and give them a clean with brake fluid using a cotton bud,is their anything I could try to stop them sticking.
Posted : 12/10/2013 1:47 pm
Replace the seals? Its easy enough job to do
Posted : 12/10/2013 1:54 pm
 Rich
Mine used to stick regularly, but since coating the pistons in silicone grease they have been fine for a couple of years.
Posted : 12/10/2013 2:07 pm
Try cleaning them with silicon lube instead of brake fluid. I use a spray one every now and then on mine.
I think the muckoff brake cleaner advertises itself as lubing the seals too but I prefer to give mine a proper clean and lube once in a while.
Posted : 12/10/2013 2:10 pm
As above, it will be crud trapped in the recess for the seals.
each time you get them moving you'll only be sorting it short term as the crud will still remain. A full strip and clean should solve it. You could get new seals but I've found a good clean usually gets them back to their best. Out if interest, which M4s do you have?
Posted : 12/10/2013 2:40 pm
Tech M4. Thanks guys
Posted : 12/10/2013 3:43 pm
If you have the new M4 brakes then you should have the phelonic pistons which is a slippery coating to reduce this so it sounds like you have the old ones (or just have bad luck). Take the bore caps off, clean the pistons/seals with oil/lubricant and it should be fine. Try not to get brake fluid on the pads!!!
Posted : 12/10/2013 6:01 pm
I remember hope recommending some kind of plumbers oil for the pistons, cant remember where I saw it or which kind though
edit...
found it...
1m17ish
Posted : 12/10/2013 6:45 pm
