Hi just wondering what the main differences are in the Hope Hub range over the years, XC - Pro - Pro 2?
Axles getting a bit bigger and less prone to snapping over the years.
Freehub design changed for ProII IIRC?
More flexibility in axle conversions as the years have gone on....
They all come after the Fatso, Ti Glide and UltraLight.
I'd say the biggest change is an increase in noise!
XC - 9(5)mm Qr only
Bulb - Qr or 20mm front & 12mm rear
Pro 2 -9mm QR, 9mm bolt thru, 15mm & 20mm, & 10mm rear, there must be a12mm version too
Pro2 Evo -as above + 142std
I believe
smaller bearings...
still great warranty back up!
Slight weight decrease too I think (due to less material on the adaptors for the front and alloy cassette body for rear).
Pro 2 also adds straight pull option and pro3 for lighter again with 3/4 bolt rotor mounts.
Thanks folks, STW come good once more - Cheers
