Following on from the thread the other day about being able to fit a tapered fork to a frame with semi-integrated headset using a Hope H cup got me thinking about trying it.
My frame is set up for 100mm forks and I want to try 120mm forks, so would that difference equate to aprox 1 degree slacker?
What is the stack height of the H cup and would that work out to 0.5 degree as well?
TIA
Posted : 30/10/2012 7:54 pm
I don't know the exact answer but expect about 1/2" stack height.
Posted : 30/10/2012 7:56 pm
Reckon you'd be pretty close with your estimate of 1.5 degrees change for adding 20mm travel plus the external lower cup.
Posted : 30/10/2012 8:11 pm
Ok cheers, any idea how long the insert part that fits into the frame is?
Posted : 30/10/2012 8:12 pm
I think the Hope technical doc's on their site give dimensions?
Posted : 30/10/2012 8:36 pm
Ah yes it looks like 10mm?
Posted : 30/10/2012 8:50 pm
