Hope floating rotor...
[Closed] Hope floating rotor problem
Further to an earlier posting, found out that the play in the back wheel under braking is in fact a the rotors fault!
Its a Hope floating jobbie and the outside braking disc is ever so slightly loose.
Can this be rectified or is it buggered (technical term!)?
Posted : 17/05/2009 8:27 pm
the braking surface is meant to float a bit compared to the spider.
Posted : 17/05/2009 8:33 pm
causes juddering under braking though. if its the design then I guess its back to normal rotors for me!
Posted : 17/05/2009 8:34 pm
Ring Hope.
Depening how old it is they might send you a new one.
Posted : 17/05/2009 8:36 pm
Happened to mine when they first came out.
Rang Hope 'Consumable part' apparently so they wouldn't replace.
Not overly impressed tbh.
Never used the floating rotor again.
Posted : 17/05/2009 8:56 pm
Is it really? I very much doubt it is.
Posted : 17/05/2009 9:15 pm
 mrmo
call be stupid but the name floating rotor.... maybe the name gives a hint as to its nature....
Posted : 17/05/2009 9:29 pm
I don't actually think it floats - it's just given that name because it's two seperate pieces.
Posted : 17/05/2009 9:32 pm
It's not meant to move, what benefit would it have from moving? **** all.
As above it's a two piece rotor to help dissipate heat under breaking.
Posted : 17/05/2009 9:48 pm
They do float on the rivets to allow for expansion & contraction of the braking surface, which can help stop warping rotors as well as saving weight.
Do any of you disbelievers actually have a floating rotor?
Posted : 17/05/2009 9:52 pm
Mine move a bit. It's only a teeny tiny bit though.
Posted : 17/05/2009 9:55 pm
 mrmo
Aluminum and Steel expand at different rates when they get hot. There is no simple way around this detail. A rotor made of two materials will be effected by this. The only question is how obvious, not whether it happens or not. I would expect the amount of looseness on a brand new rotor to be negligible, but once it has been heated and cooled a few times a little play will develop.
All a matter of tolerances and usage as to how obvious and how quickly the effects will become evident.
Posted : 17/05/2009 10:02 pm
