Hope brake adaptor ...
[Closed] Hope brake adaptor - Am I being a numpty?
Trying to fit my Hope M4 Calliper to Magura Thor forks.
Caliper is a No.3, IS mount for 185mm rotor, I'm using Hopes own [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13735 ]HBSM20H[/url] adaptor with a new 205mm rotor.
If I fit it one way round, its too far from the rotor, the other way, the caliper body catches on the adaptor. [b]what am i doing wrong???[/b]
Posted : 25/01/2010 10:15 pm
Turn the adaptor so the top in your picture is at the bottom. Think you have it the wrong way up.
Actually convinced its on upside down.
top bolt become bottom et voila.
Posted : 25/01/2010 10:26 pm
kev- the bottom picture has the mount t'other way up. Neither works is his point.
Double check the packaging and marking on the adaptor. Last time I got a disc adaptor from CRC they'd labelled the packet wrong - always worth checking.
Posted : 25/01/2010 10:34 pm
Yeah sorry mate just looked carefully at top pic. the adaptor is pushing it too far away. In my head i'm thinking that the caliper is for a 185 disc and you've got an adaptor taking a 165 to 205. but i've been wrong before.
Is that really a 205 disc looks smaller than mine did.
Posted : 25/01/2010 10:39 pm
There was a thread on this subject only last week, now on the next page at this moment. Seems that Thors have a built in +20 mount so you'll need a larger disc again.(original thread started by hamishthecat.)
Posted : 25/01/2010 10:58 pm
Oops, I also hadn't notice that you were starting with a 185 mm caliper - I'd assumed it was a normal 160 mm rotor caliper,so with the Thor's 180 rotor post mount and a +20 adaptor you were on the money.
Doesn't look like it's possible to fit in a PM to IS adaptor without adding +20 to the rotor. New caliper time?
Posted : 25/01/2010 11:09 pm
Posted : 25/01/2010 11:12 pm
