Hope BB creaking - ...
[Closed] Hope BB creaking - Threadlock?
[#2836411]
I run a Hope BB in my Wolf Ridge. Very happy with its performance, but every few months it develops a creak under load. Just tightening the cups in situ doesn't help. I can rectify this without fail by removing the cups, cleaning and greasing (Finish Line teflon) the threads, and reinstalling it.
While this fixes it I'm starting to worry that if I keep having to do this, the BB shell threads on my frame are going to suffer.
I was thinking some threadlock might solve this problem, but don't really know if it's advisable.
Anyone know if threadlock is viable, or had similar experience?
Posted : 10/06/2011 10:49 am
Wrap some PTFE tape around the BB cup threads.
Posted : 10/06/2011 10:53 am
Hope BB's can also creak where the bearings sit in the bb cups - what you can do is press out the bearings, clean both surfaces with something such as isopropylalcohol, then smear a light coating of lok-tite on the surface of the cups where the bearings sit, then press the bearings back in again.
Posted : 10/06/2011 11:27 am
As the routine above always fixes the creak temporarily, I don't think it's the bearings but I guess I could try that and see. Stranger things have happened.
Reading up on creaky BBs I'm now wondering if this is a facing issue.
Posted : 10/06/2011 11:36 am
As I read your post, you've got a threaded bottom bracket ? I'd strenuously avoid putting loctite anywhere near a thread that size on a bike frame. Even the low strength stuff will put up a significant fight next time you try to remove the BB. Personally I'd have the BB faced by someone who knows what they're doing, clean the threads until sterile & apply fresh grease. Torque BB to recommended torque.
£0.02
Posted : 10/06/2011 12:36 pm
Yeah Dave that's what I was wondering about re loctite. It was supposed to have been faced by the shop but couldn't hurt to have it looked at again.
Posted : 10/06/2011 2:23 pm
Yes Use Loctite 'Bearing Fit' rather than one of their threadlocking products..
Loctite 641 or 601
Posted : 10/06/2011 4:25 pm
[url= http://www.singletrackworld.com/forum/topic/bb-issue-bb-spins-in-frame ]check this thread[/url]
Posted : 10/06/2011 4:43 pm
