Home made Fat Bike?
[Closed] Home made Fat Bike?
[#5967679]
Been thinking of doing a cut & shut on my old Prince Albert Frame & set of rigid 29er forks, with all the other bits of junk I can't be arsed to flog was thinking I could eek out a Rat Fat Bike with just a set of wheels & tyres needed for the shopping list. Anyone done similar / can think of pitfalls or reasons not to?
Posted : 17/02/2014 1:40 pm
cynic-al cut and shut a fat Marin bouncer.
Posted : 17/02/2014 1:45 pm
Some one did it with an on one, I did it with a Marin FS and am planning a 2nd.
Will your forks have clearance? Std 29er ones won't.
How will you get the chainline sorted? (I used a 88mm chainset and messed with the spacing - its marginal)
Posted : 17/02/2014 1:46 pm
Ah, yes so he did - will have to search that one out, although looking to stay rigid here
Posted : 17/02/2014 1:47 pm
29er frame with 26" fat wheels?
Posted : 17/02/2014 1:54 pm
clubber - Member
Nope, 26er I think.
Posted : 17/02/2014 1:55 pm
I'm working on the basis of cutting near the crown & installing inserts to increase axle width to 135mm & build the front wheel onto a rear hub, so this should give me clearance.
On the bottom bracket, again I was thinking of cutting away from frame & increasing to 100mm width again with insert, could then either get 100mm BB or even more make shift get a HT2 crankset & cut & shut that to suit the BB width - or is that stretching the bounds of metalurgic possibilities ? Could manage 1x but would prefer 2x if I can.
Posted : 17/02/2014 1:58 pm
Chainline/BB/Cranks are the place to start unless you are only going half-fat (front only) or 29+.
The other option would be the 26x3" Dirt Wizards
doner frame is 26er, forks are 29er
Posted : 17/02/2014 1:59 pm
The home made 100mm crankset has been tried - check MTBR. It was unsuccessful.
Posted : 17/02/2014 2:23 pm
I'd just buy fat forks.
Converting std HT2 cranks to 100mm would be a feat of engineering IMO. In fact widening the BB seems fraught with problems IMO.
Posted : 17/02/2014 2:25 pm
Should be lots of steel on one fatty forks getting sold pretty soon as people fit the carbon ones.
Posted : 17/02/2014 2:30 pm
was my thoughts too & if it has already been tried ^^ 🙁
A mate has a Pugsley, so will have a good look at that before I get the hacksaw out, hopefull plan to have a go with widening the BB & forks though, not like I have much to lose
Posted : 17/02/2014 2:34 pm
Can you not get square taper BBs to fit given how much simpler that would make the whole process?
Posted : 17/02/2014 2:35 pm
Bike 24 do a [url= http://www.bike24.com/1.php?content=8;navigation=1;product=7173;page=1;menu=1000,2,81;mid=170;pgc=0;orderby=4 ]truvativ bb[/url] for about thirty quid then just pick up cheap cranks.
Posted : 17/02/2014 2:39 pm
💡 thats just the kind of blindingly obvious idea I need to hear 🙂
Posted : 17/02/2014 2:40 pm
 Keef
I have a kona unit 29er that I converted 3 years ago,rides great,in fact it worked so well,I did one for a mate too...
Both are ss only,bb width for chain/chain stay/tyre clearance is the main issue,loads of measuring,thinking etc,cutting and welding is the easy part 😉
Posted : 17/02/2014 2:54 pm
