Home brew tyre seal...
[Closed] Home brew tyre sealant
Anyone made their own tyre sealant? Did it work?
If it did work, what recipe did you use?
Posted : 12/05/2013 11:52 am
Art latex,splosh of windscreen wiper fluid and a soupcon of water (season to taste).
Posted : 12/05/2013 11:54 am
What about something to bulk it up and seal punctures? I've read about folk using glitter or grated rubber?
Posted : 12/05/2013 11:59 am
Parmesian?
Posted : 12/05/2013 12:01 pm
cafe latex uses used coffee grounds i believe.
Or just use stans, £20 for a bottle and it lasts a couple of years of tyre changes across three bikes for me!
Posted : 12/05/2013 12:12 pm
grated rubber
I thought it'd be a good idea to grind up the knobblies someone cut off a wetscream & add them to tubeless goop.
It wasn't.
Killed the blades of my spice grinder instantly 😕
Mark Datz always used to reckon that duk down (from a duk) was the stuff to use. Actually, if you could chop it up into small pieces, it's probably not a bad idea.
Posted : 12/05/2013 12:59 pm
