were the hell is the air cap to add more presure what leg is it in i dont want to start undoing thing and brake it please help
cant even find it on the service pdf
[url= http://www.marzocchi.com/template/detailProdotti.asp?LN=UK&idC=1579&IdFolder=113&idMY=56330&IdOggetto=56397 ]The picture in this site[/url] shows what looks like an air valve under the red cap, & though the [url= https://www.marzocchi.com/admin/download.asp?LN=UK&idC=1579&Campo=ManualeInglese&IDFolder=126&IDOggetto=56399 ]manual[/url] doesn't have a picture. In the small print in the air pressure section, it says it's under that cap
If they are this years model then they don't have air chambers, they are coil only
yep looks like coil only can i change the coil or is it fixed
i've not looked into different springs as mine suite me fine at 12st
Best to check with Windwave for springs if you need em
took it out today for a proper ride wow thease forks are amazing on my mondraker prayer
