Help with gearing
[Closed] Help with gearing
[#5321794]
Just got a 2x9 setup fitted but when pedalling its tending to change gear on its own. Is this something I can easily adjust myself or do I need an lbs?
Posted : 10/07/2013 6:25 pm
Sheldon Brown or you tube are worth a look at , I've managed to index gears and I'm a proper mechanical numpty .
Posted : 10/07/2013 7:12 pm
too much tension in your cable
is it SRAM of Shitmano?
Posted : 10/07/2013 7:15 pm
SRAM chain, shifters, and rear mech with shimano front mech and cassette
Posted : 10/07/2013 7:25 pm
ok you cable tension is probably off
you can adjust the cable tension at the shifter, slacken it off a bit at a time until it indexes without jumping
Posted : 10/07/2013 7:30 pm
