Help, what is this ...
[Closed] Help, what is this bb and how can I remove it?
Hello, can anyone tell me what BB this is and how can I remove it asap if possible without the correct tool. So far one bike shop has sold me the wrong tool and my 2 LBS have not either been able to identify the BB or get it! I am trying to build bike as asp and seemed to be cursed!
All help appreciated
thanks
[img] ?v=0[/img]
[img] ?v=0[/img]
[img] ?v=0[/img]
Posted : 11/07/2009 10:06 am
Just looks like a truvativ bb, to get it out without tools though erm screwdriver & hammer probably work.
Posted : 11/07/2009 10:19 am
 Bez
It looks like someone's already tried and (unsurprisingly) failed with the screwdriver and hammer approach...
Posted : 11/07/2009 10:20 am
Not sure of brand (Truvativ?) but you need a BB tool for an 8 notch (or 8 prong) BB tool) and a large wrench to fit the tool.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=17702 ]one here on chainreaction[/url]
definitely do not try with anything but the appropriate tool! you'll just f*ck up the bb and not get it out.
Posted : 11/07/2009 10:22 am
you can easily remove that with a screwdriver and hammer. Just tap it gently round.
Even the most hammerfisted spanner monkey should be able to do that
Posted : 11/07/2009 10:32 am
That's an old Truvativ Giga-Pipe, I think! Nope I'm pretty certain.
Posted : 11/07/2009 10:41 am
the bloke in 2nd local bike shop took hammer to it and failed
Posted : 11/07/2009 11:23 am
Plus gas and heat? Are you sure you are attempting to turn it the right way?
Posted : 11/07/2009 11:38 am
You need the old style shimano 'prong' tool. It's the same tool used to remove the lockring from older XTR chainsets, the ones where you could remove the spider. Hammer and screwdriver will not work if the bb is in as tight as it should be. Worst case is to use a pair of pipe grips and undo it that way, it wi destroy the cups though.
Posted : 11/07/2009 11:55 am
same tool as for Middleburn lockrings.
I have one you can borrow if you're anywhere near malvern.
Posted : 11/07/2009 12:03 pm
If it the Middleburn spider tool I too can help. I have the tool for you, near Ammanford/ Pontardawe, S Wales.
Posted : 11/07/2009 12:11 pm
How about a lockring spanner, any LBS should have one!
Posted : 11/07/2009 12:15 pm
 Keef
if you haven't got the 8 prong tool,and you don't mind ****g up the BBcups,then in an emergency, a set of Stillsons,and if necessary,a length of tubing (for extra leverage) is the way foreward
Posted : 11/07/2009 12:25 pm
I took one of those out last week I used the hammer and screwdriver method as I wasn't going to use it again and didn't want to spend about £10 quid on the tool.
One side came out ok but had to get the stilsons on the other side as it was a pig to turn.
I binned it straight after.
Posted : 11/07/2009 1:46 pm
You must have 2 pretty rubbish bike shops near you any mechanic worth his salt would recognise that straight away. As has been said Lockring wrench or 8 prong socket wrench is what you need plus release spray and or heat.
If I was in a bike shop and the mechanic came anywhere near my bike with a hammer and screwdriver he would need to go to casualty and have them removed from his person using the correct surgical tools.
Posted : 11/07/2009 2:35 pm
thanks folks removed safely
Posted : 11/07/2009 4:56 pm
Same here!
@hicksville - so how did you remove them?
Posted : 11/07/2009 5:36 pm
