The uturn adjuster on my Revelation's is pretty much jammed. If you I really force it I can get a couple of turns out of it but its hard work and doesn't sound too healthy. Has this happened to anyone else and is there an obvious solution?
They are a set of 2010 Team's if that makes any difference.
Ta,
Jamie
Posted : 09/10/2010 4:46 pm
Take the adjuster off with a small Allen key, careful you don't drop the ball bearings.
Clean the top of the adjuster on the fork, apply a bead of grease and the re-fit the balls and the adjuster.
Job done
Posted : 09/10/2010 5:29 pm
Magic, that seems to have done the trick.
Thanks,
Posted : 09/10/2010 6:56 pm
