Help - sticky brake...
[Closed] Help - sticky brake pistons (hope mono m4)
Good couple of weeks just had the verdict that my stuck rear shock wasn't worth fixing and then went down the garage to sort a minor bit of brake rub and I'm tearing my hair out.
Brake is a Hope Mono M4, the black and gold ones from about 2006.
The pistons on the hub side and the large/leading one especially are sticking luck the proverbial to a blanket.
Double checked the alignment and thats fine and I have tried the holding the piston in thing with no joy.
Brakes feel solid but I haven't bled them tonight.
I have lubed the pistons with dot5.
What do I try next? I don't ideally want to fork out for new brakes but this is not the first time I've had this issue.
Posted : 27/03/2012 11:45 pm
Oh and thanks in advance for any replies and please excuse the typos. Smartphone not the best for this!
Posted : 27/03/2012 11:47 pm
my m4's had sticking piston and i just forced the piston in and out a few times with a massive screwdriver while chucking on some silicone lube
seems to have done the trick
good luck
Andy
Posted : 28/03/2012 12:16 am
Check out [url= http://steveukmtb.wordpress.com/hope-caliper-overhaul-minitrialsm4v2m6 ]this guide[/url] I compiled. Should get you going again.
Don't use a screwdriver on the pistons as you run the risk of cracking them.
Posted : 28/03/2012 12:46 am
thanks. will look at the guide later on.
Posted : 28/03/2012 6:09 am
As 3fish says, that's the definitive response, and Steve thx I used that page several times.
Posted : 28/03/2012 6:21 am
I was recommended Red Rubber Grease for lubricating the pistons as it does not degrade the seals like some silicone lubes. After a thorough clean with some cotton buds I applied the grease (google search found a supplier) to the pistons and they have been running smoothly ever since.
Posted : 28/03/2012 7:10 am
