Hi all, I have a few questions if anyone can help...
1. Does anyone know if I can run my old Hope Mono Mini discs with new Shimano SLX calipers?
2. Do shimano SLX calipers work on either post mount or Internation standard, without the need to buy a specific version for each?
3. Without adapters (i.e. as standard) would they run on 160mm discs?
Thanks. I look forward to your replies!
1. Don't know, but I don't see why not.
2. The calipers are post mount. You need an adapter for IS.
3. Yes.
1. yes, should do. may have to place a few washers under caliper body if the hope discs come up a little bigger than shimano.
2 & 3. as above.
(3. they usually come with IS adaptors.)
