Dual Air setup advi...
[Closed] Dual Air setup advice
[#710098]
Just got myself some new Revelations 426 Dual Air forks.
Was reading about the +ve and -ve air chambers, and the effects of putting more or less psi on one vs the other.
Wondering if there is a consensus out there about the best way to set them up, more psi in the +ve, the -ve or equal.
Posted : 15/07/2009 2:51 pm
With my Reba's I tried more in the lower chamber from reading around but found it too sensitive. I run them equal at the mo and find it suits me. Think you need to have a play and see what suits you
Ivan
Posted : 15/07/2009 3:28 pm
start by putting the correct amount for your beergut in the positive.
match it with the same neg.
than add neg to taste after testing.
Posted : 15/07/2009 3:29 pm
Ivan I did the same with my Rebas and noticed sod all difference. Like you i've gone back to equal amounts in both.
Posted : 15/07/2009 3:54 pm
