[HELP] Rockshox lea...
[Closed] [HELP] Rockshox leaking air between chambers
[#3944775]
Hi,
I have a pair of 2009 dual-air Revs that I'm having some trouble with. When I pump one side up the pressure is equalised in the other chamber. It doesn't matter if I pump the +ve or -ve up first, the air leaks into the other one and has the same pressure.
Do you know what can cause this problem and how I can fix it?
Many thanks in advance!
Posted : 05/05/2012 12:20 pm
 S_J
Seal between pos and neg chambers has probably failed. Quite a common issue. Either perishes or gets pinched on install.
Posted : 05/05/2012 12:27 pm
It is a common problem, I've just fixed a similar one on my Pike Airs.
So long as you've got the correct seal kit and the right tools, the fix is dead easy. Basically, as S_J has said a seal is ronnied somewhere and needs replacing. Give either LoCo Tuning or TF Tuned a buzz and they'll have the appropriate seal kit in stock, or otherwise it might be a good idea to send the forks off for a service.
Posted : 05/05/2012 12:32 pm
Thanks for the insight. That does make scene to me now. Ive had a look in the manual and I think I know which two seals it could be. Do you know where I can buy these two seals?
Posted : 05/05/2012 12:36 pm
Thanks for your response PMJ. Would they be able to sell me the two seals or would I need the full kit at 20 odd pound? It seems a lot of money for two o-rings.
Posted : 05/05/2012 12:38 pm
Not sure to be honest - I bought a full seal kit because I wanted to overhaul my forks myself. The chap behind LoCo is reputedly very good so you could give him a call and talk it through with him.
The strip down for the Dual Air internals on Rockshox forks is relatively straightforward - [url=
on YouTube[/url]
I should reiterate that having the correct tools is an absolute must...you can get away with not having a bike stand, but the 24mm socket, snapring pliers and 15wt fork oil is a prerequisite.
Posted : 05/05/2012 12:43 pm
I'm taking them apart now. I have the 2009 service manual up on my PC and all the oils I've still got from a while back. I've got a pair of circlip plies too 🙂
I should probably get the full kit, money is just a little tight having this hobby as a student. If I know it's just a specific o-ring, I'd like to tray and get my hands on it.
Thanks so so much for the advice, will let you know in 10 when I have them apart.
Posted : 05/05/2012 12:54 pm
I asked a similar question about Dual Air Rebas on [url= http://singletrackworld.com/forum/topic/rock-shox-reba-dual-air-problemstupidity ]this[/url] thread a few weeks ago. Bought the eBay seals for £8.75 and they were fine.
That was for Rebas, but I think he sells Revs kits too - they may be the same anyway.
Posted : 05/05/2012 1:43 pm
Nice one Lee1989!
Let me know how you get on, if you get stuck then you're welcome to give me a shout.
Posted : 05/05/2012 1:59 pm
