Help please !!!
[Closed] Help please !!!
[#5436101]
I've just started putting more bits in to my build to find out I've bought the wrong size front mech.
I need a 28.6mm,Is there anyway I can bodge it to make it fit ???
Posted : 18/08/2013 7:59 pm
If you've bought too big it's probably possible to shim it (deffo if shimano)
Posted : 18/08/2013 8:02 pm
Yes mate it is shimano.
Thanks ill look into it
Posted : 18/08/2013 8:10 pm
Shim material can be pretty much anything, electrical tape or a chopped up beer can are just as good as the shims you get with some mechs.
Posted : 18/08/2013 8:17 pm
the mechs come with convertors/shims in the box
Posted : 18/08/2013 8:24 pm
But it is an excuse to first drink a beer then carefully shape one yourself. Please note the first part is important 😉
Posted : 18/08/2013 8:30 pm
Haha yeah any excuse for a beer rusty 😀
I haven't got any converters .
Posted : 18/08/2013 8:36 pm
If you need to pad it out just whack a bit of old inner tube in there. Works perfectly on my inbred!!
Posted : 18/08/2013 8:39 pm
That ads is a bloody good idea I will try that 1 now ! Cheers
Posted : 18/08/2013 8:41 pm
 JoeG
28.6 shims come with most Shimano front derailleurs. If you didn't get any, then your LBS or someone on STW probably has a set lying around. I'd suggest a wanted add on the classified forum.
Item 3 in this [url= http://www.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/FD/EV-FD-M780-3168_v1_m56577569830753749.pdf ]XT Tech Doc[/url]
Posted : 18/08/2013 8:44 pm
Thanks for all the help fellas I'm going to try the inner tube then the bike shop
Posted : 18/08/2013 9:37 pm
