Help me source a fr...
Help me source a freehub or pawl for a friends bike please
Lady friend asked me to look at her bike as the freehub was broken. On opening it up it was gunged up, but surprisingly also missing one of the 3 pawls. No idea where it’s gone , potentially it’s fallen out when someone has tried to service it previously
hub is a chosen 150t which appears to be a Chinese firm Akin to novatec. Rsp appear to make new freehub a for chosen hubs but for a 150p model so no idea if that will fit. The ideal solution is to just replace the pawl, however I’ve tried a few from old wheel sets I’ve had hanging around and none fit
failing that it’s a wheel build on a new hub, which I’m keen to avoid given I can’t build wheels!
Posted : 05/12/2023 3:18 pm
Any picture of the pawl you need - I have some spare pawls from a Chosen hub that came on a Rise and died so you are welcome if, on the off chance, they are same.
Posted : 05/12/2023 3:36 pm
@vmgscot
cheers fella
does this work?
https://www.flickr.com/photos/193301801@N05/53377750414/in/dateposted-public/
Posted : 05/12/2023 3:57 pm
Sorry, the pawls are not the same - those look quite complex. Ah well, was worth a shot.
Posted : 05/12/2023 5:13 pm
Is this them?
https://www.ebay.co.uk/itm/314816992278?
Posted : 05/12/2023 5:30 pm
Hard to tell! One of those looks similar shape but unless it’s spot on it’ll probably not fit. Maybe worth a punt though👍
Posted : 05/12/2023 6:14 pm
RSP Shimano 9/10 Speed Freehub Body For 150P Chosen Hub | Tredz Bikes
Bugger, I see your aware of that model, but it looks the closest option
Posted : 05/12/2023 6:26 pm
@vmgscot
cheers for having a look anyway, appreciated 👍
Posted : 05/12/2023 7:38 pm
That looks very like a chosen freehub
Posted : 05/12/2023 7:58 pm
That looks very like a chosen freehub<br />
what do you mean? Ta
Posted : 05/12/2023 8:15 pm
If you put it back together it'll probably work perfectly well with just two pawls. I helped a mate service a set of Hopes and that was down to only one and still worked.
Posted : 05/12/2023 9:56 pm
I thought about that but I’d need to permanently remove one of the springs. Also, I’m not convinced  of the robustness of removing 33% of the pawls!
Posted : 05/12/2023 11:28 pm
It's not ideal but how much power is she likely to put through it? If it'll take 2000W with 3 pawls is it really a problem?
Posted : 05/12/2023 11:33 pm
