Help ID my Speciali...
[Closed] Help ID my Specialized....
[#6483784]
[url= http://www.pinkbike.com/u/saladodger/album/Specialized-S-Works-Stumpy ]What Am I[/url]
Hi y'all
Bought the shown frame as a Soecialized S-Works Stumpy but it had been stolen recovered and as such stripped of decals, frame number and indeed original paint job. However it was clearly a Spesh and the local plod happily confirmed the crime ID for the frame so I was happy to hand over my cash. I had it stripped and reprinted in matt white but before I acquire and apply the correct decals I need to know if I'm missing anything? I am aware that the Stumpy Expert looks similar.
Is there anybody out there who can confirm from the pics the model of the frame pictured? The seller gave me a set of bearings also which appeared genuine and had Specialized S Works SJ 120 FSR on the packet. Does this seem right?
Thanks in advance.
Posted : 14/09/2014 9:15 pm
2006 Stumpy FSR Pro, I think. Not sure it's S-Works though, as I believe that the S-Works was carbon in 2006.
Posted : 14/09/2014 9:16 pm
Or 2007? S-works had the shock reservoir on the stay. Specialized have an archive section their site - shouldn't take too much to check...
Posted : 14/09/2014 9:19 pm
The res is on the stay as pictured. Will try the archive but don't let that stop anymore suggestions or confirmations. The expertise on here is ace! And quick....
Posted : 14/09/2014 9:27 pm
That's a 2007 - did away with the lower shock bush (as in CFHs linked photo) and replaced with a cartridge bearing assembly. Not an S-Works.
Top tube changed too - 2006 ones had the model name (Comp/Expert/Pro) in a hydro formed 'dent', the 2007 ones were bit more complex. Seat tube design changed too IIRC.
Posted : 14/09/2014 9:39 pm
Thanks guys, keep observations coming but please elaborate as to why it is or isn't....
I have narrowed it down to 2007 due to the above and the fact it only has 1 set of bottle bolts. Also the rear shock as a blue twist top which suggests it is the FSR Expert frame as opposed to the FSR Pro which appears to have a different brain on the rear stay (brown top).
Any advance on my beliefs...?
Posted : 15/09/2014 1:07 pm
Also 100% it's a 2007 as the down tube does not taper towards the bb (as per 2006) and there is a definitive curve to the down tube at the same point, with no reduction in tube size. Cheers
Posted : 15/09/2014 1:10 pm
 iolo
It's an ok bike. Does it make much of a difference what it is as long as you're happy with it.
Ride it and enjoy.
Posted : 15/09/2014 1:17 pm
Just want to know what decals to get! Nothing more annoying than some smart-ass telling you "that's not a 2006 stumpy thingymibob cos it's only got one bottle cage mount....". A bit of research can save you having to address such a comment....
Posted : 15/09/2014 11:28 pm
Leave it plain white. Looks good I reckon.
Posted : 15/09/2014 11:33 pm
