Helmet padding glue
Helmet padding glue
Ive got a helmet and the pads to make it comfortable/adjist the fit, are open cell foam, with some fabric attached to the front and back surface of the foam.
This fabric then attach3s to the velcro on the inside of the helmet.
However the fabric has become detachwd from the foam, so the pad is no longer secured in the helmet.
Any idea what i can use to attach the fabric to the foam so im back with a functioning helmet?
Thanks
Ian
Posted : 14/07/2023 9:21 am
Needle and thread?
My first job on buying a new helmet is to sew some rough stitches around the edges of all the pads to stop them coming apart. Just very rough - takes about 30 mins - it's not the Bayeaux Tapestry.
Or are you saying the foam is too bulky for this?
Posted : 14/07/2023 9:30 am
I had the exact same issue. Used Loctite All Purpose adhesive. Spirit based clear glue like UHU. I tried late (Copydex) but it wasn't as good.
Posted : 14/07/2023 9:51 am
don't know why linking doesn't work - add amazon.co.uk to this string
/Padding-Universal-Bicycle-Airsoft-Motorcycle/dp/B0B3ZYCGQK/ref=asc_df_B0B3ZYCGQK/?tag=googshopuk-21&linkCode=df0&hvadid=606636062855&hvpos=&hvnetw=g&hvrand=14964180550327436625&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1007150&hvtargid=pla-1736708777680&psc=1
Posted : 14/07/2023 12:06 pm
Tacky PVA glue. I've used it for similar things.
Posted : 15/07/2023 12:35 am
What glue would people recommend to glue the pads back to the helmet polystyrene type material please?
Posted : 14/09/2024 11:36 am
Double sided tape probably, but not that foam stuff.
Or that foam stuff, which is pretty sticky.
Posted : 14/09/2024 2:06 pm
Yeah double sided take. 3M stuff for preference. But get it right because when your press it down its not coming off without a fight
Posted : 14/09/2024 2:11 pm
Thanks.
Posted : 14/09/2024 2:16 pm
You can buy sticky velcro hook dots to stick on the polystyrene of the helmet, and the pads (stitched, new or whatever) just stick to them
Posted : 14/09/2024 2:57 pm
Sweat gets my 3M tape off after a while. What specifically are you using? VHB?
Posted : 14/09/2024 10:18 pm
