heckler torque sett...
[Closed] heckler torque settings?
[#3499843]
got a 2011 and need to replace the main pivot bearing and bushings but can't find the torque settings on the web, any guidance please ?
Posted : 28/12/2011 8:26 pm
cheers mine is the new design without the pinch bolts is it likely to be the same.
Posted : 28/12/2011 9:05 pm
Sprocker, mine is a 2011 and just done the pivot bearings. The guys at SC have yet to put together a guide but sent me the PDF for the Butcher, basically the principle is the same. The main pivot is set up much like a headset, basically you're looking for free movement without any lateral play. Hope that makes sense, let me know if you need more guidance.
Posted : 28/12/2011 10:36 pm
cheers looked at the butcher and the pivot assembly looks very similar and you only torque it to 35 - 40 in/lbs which maybe why I need to change it so quick as I tightened it beyond that.
Posted : 29/12/2011 10:50 am
