Replaced a bushing as there was play in the rear of the bike and there is still play, its definitely the rear shock so looks like I might have worn the mount kit. Looked at the tf site but lost at what size i might need as i measured my kit @35mm and bolt internal @ 8mm
[url= https://farm1.staticflickr.com/719/22349060172_a7b742087c_b.jp g" target="_blank">https://farm1.staticflickr.com/719/22349060172_a7b742087c_b.jp g"/> [/img][/url][url= https://flic.kr/p/A3ULXE ]Untitled[/url] by [url= https://www.flickr.com/photos/nzrich/ ]Richard Munro[/url], on Flickr
Assuming you are running Fox/ RS just select a standard 12.7mm M8x35. http://www.tftuned.com/heavy-duty-mount-kit-127mm-m8/p2937 Select the Cane Creek option if you are running CC as they use different eyelet bushes http://www.tftuned.com/cane-creek-mount-kits/c205 HTH
Put a kit on my old Kona and it made a fair difference. Certainly a better design than the "top hat" original.
Just mail them if you are confused 💡
I put the HD mount kit on my Zesty with Fox. I'd do it again without hesitation on another bike.
As above, unless you have CC, it'll be 12.7mm.
Just reread. Sorry, yep. Check the how to measure page here http://www.tftuned.com/mobile/tech-help/71-mount-kits-and-bushings-for-rear-shocks-a-guide
Assuming you followed that, M8*35 with 12.7 poly bush sleeve is quite on the cards.
