Best Ti Caliper Bol...
[Closed] Best Ti Caliper Bolts??
[#7406754]
Need 4x caliper bolts for M9000 brakes
Neither caliper uses an adaptor
Could do with 2x for the levers as well
Where's the best place for decent quality ones?
Posted : 21/10/2015 5:19 pm
Get all my Ti bolts here ➡ http://www.pro-bolt.com/
Very good quality, good enough for MotoGp 😉
Posted : 21/10/2015 5:27 pm
Uberbike ones seem reasonable so far and far kinder on the wallet than some suppliers.
Posted : 21/10/2015 6:09 pm
 sv
Pro bolt are good quite £££ though. Aluminium for the levers perhaps?
Posted : 21/10/2015 6:33 pm
 nach
Dunno if they're [i]the best[/i], but RaceTi are a bit cheaper: http://www.raceti.co.uk/titanium-taper-head-bolts-13-c.asp
Posted : 21/10/2015 7:18 pm
I went with the Uberbike ones too.
Posted : 21/10/2015 7:37 pm
Sorry for thr hi-jack. How much weight do you save with ti bolts?
Posted : 21/10/2015 7:52 pm
Just bought some M9020 brakes and they came with ti caliper bolts in the box.
Otherwise Pro-bolt, pricey but good quality i.e actually have a 5mm Allen head rather than 5.5mm like some others I've bought elsewhere.
Posted : 21/10/2015 8:16 pm
 br
[i]Sorry for thr hi-jack. How much weight do you save with ti bolts?[/i]
Half the weight of steel.
Posted : 21/10/2015 8:33 pm
Seemed heavy when I pulled them from the box - OEM though these from CRC
Will weigh them tomorrow
Posted : 21/10/2015 9:05 pm
The Mt Zoom ones on XC racer have been perfect for me from a few years.
Posted : 21/10/2015 9:27 pm
 DanW
I use Toronto Cycles for everything. Pro-Bolt may be *better* but they're significantly more expensive and the bolts from Toronto Cycles have been going strong for coming up to 10 years now.... [rushes off to replace them 😀 ] I have a bad habit for ordering a huge box of stuff from them as it a bit like Ikea- ooooh cheap, I definitely need 5 of them 😳
Posted : 21/10/2015 9:28 pm
Why's pro-bolt better?
Posted : 21/10/2015 9:39 pm
 DanW
No idea in the real world but they are always supposed to be *better*. Since the Toronto Cycles ones do the job perfectly I've never really looked in to justifying anything more expensive
Posted : 21/10/2015 11:12 pm
Only thing I've found with Toronto cycles is the colours can be a bit dodgy. Stick with 'natural' and they're great though!
Posted : 22/10/2015 9:00 am
Tried Superstar Ti disc bolts many moons ago. Made of cheese, and the threads are very poor quality. ProBolt are over the top Tbf but are a quality item with rolled threads. Not seen Toronto Cycle before will have a look.
Posted : 22/10/2015 9:24 am
Ti ones were in the box 😀
Posted : 22/10/2015 10:02 am
http://tibolts.co.uk/
Got some and seem good to me.
Posted : 22/10/2015 1:01 pm
Tibolts.co.uk is/was Superstar, and the ones I had years ago were utter shit - distorted and shallow heads being the biggest issue. Would use Toronto Cycles instead.
Posted : 22/10/2015 1:25 pm
Ask Hope what Ti bolts they provide with their Special Edition range of brakesets (M5s for calipers, M4s for levers). The quality is excellent.
Posted : 22/10/2015 2:32 pm
take one bolt out, do the other up mega tight, hey presto, half the weight saved at no cost.
alternatively, blow your nose before riding for a similar weight loss
Posted : 22/10/2015 3:08 pm
Corrosion resistance without the cheese-like quality of alloy bolts is maybe a better reason. Or, they look better longer as I'm a bike tart.
Posted : 22/10/2015 3:34 pm
Stan, all the way! http://www.tartybikes.co.uk/search.php?keywords=stan&
Posted : 22/10/2015 6:10 pm
Posted : 22/10/2015 6:32 pm
