Headset without cro...
[Closed] Headset without crown race?
[#819229]
I have taken the fork (Marzocchi Bomber) off my Giant XTC2 and I noticed that the crown race is not fitted on the steerer. Is that normal? The headset is a semi integrated FSA. Thanks for any explanation.
Posted : 27/08/2009 11:56 am
must be "jammed" in the bottom of the headset, or dropped out without you noticing ?
*suppose they could make one with an integrated race but it'd be a bastard to fit the fork into the frame & would prob bugger the bearings I'd have thoughrt
Posted : 27/08/2009 12:02 pm
I had a good look in the bottom of the headset and definitely is not there; what I can see is the bearing. What is strange, is that I have ridden the bike for months without noticing anything supposedly wrong.
Posted : 27/08/2009 12:09 pm
Is the bearing on the steerer still? If so, the crown race will be under it and they'll have corroded together.
Posted : 27/08/2009 12:11 pm
No the bearing is out. I'm really baffled. I think I'm going to buy a new headset.
Posted : 27/08/2009 12:28 pm
I'm stumped.
I once (somewhat stupidly) went on a ride after fitting new forks. It was only when I got back and found a mess of scratched metal that I realised I'd never fitted the crown race. I'd wondered why the steering was so bad.
Posted : 27/08/2009 12:30 pm
time for some photos ??
Posted : 27/08/2009 12:32 pm
I'm at work at the mo 😉 but I will post again with some photos.
Posted : 27/08/2009 12:39 pm
rolfharris - Member
I'm stumped.
I've fitted the upper race upside down before :lukeb:
Posted : 27/08/2009 12:40 pm
[url= http://mtb.fullspeedahead.com/downloadfly.aspx?download=downloads/2010+Headset+Technical+Catalogue+PDF+(Low+Version).zip ]FSA headset catalogue link[/url] Had a quick look & can't see one without separate race
Posted : 27/08/2009 12:42 pm
Is the race within the bearing?
Posted : 27/08/2009 12:43 pm
Looking at the FSA catalogue was the first thing I did.
No the race is not within the bearing. The headset consist of (from top to bottom: cup, seal, compression ring, top bearing and bottom bearing.
Posted : 27/08/2009 12:53 pm
well, suppose you need to check fork crown, base of headtube and base of bearing for damage, then refit the fork & see if the headset is smooth without
If it isn't, then we're back to "lost race"
If it is, I guess you [i][b]could[/b][/i] run it like that but might well bugger the bearing early (& maybe the fork/frame if it all collapses)
(can you identify the model from the catalogue & compare vs the exploded diagrams ?)
Posted : 27/08/2009 1:03 pm
No I couldn't identify the model from the catalogue. I think is time for a new headset, probably a Hope, which apparentely are great.
Posted : 27/08/2009 1:12 pm
FSA Orbit XLii - £20ish reliable and last ages. Why spend more?
Posted : 27/08/2009 1:14 pm
FSA are great, IME
Ahem, just noticed 'Semi integrated' so the XL2 is no good but I's still stick with a cheaper FSA unless it's to make the bike look nice in which case, Hope's spot on 🙂
Posted : 27/08/2009 1:18 pm
I agree that £62 for the Hope is a lot of money when you can get a decent headset for around £25. But as Clubber said it makes the bike look nice 😛
Posted : 27/08/2009 1:27 pm
- you've hidden that race haven't you, just so you can buy a tarty Hope !
Posted : 27/08/2009 1:30 pm
LOL 😆
Posted : 27/08/2009 1:35 pm
