Headset help- 1+1/8...
[Closed] Headset help- 1+1/8 semi to tapered?
[#10128258]
Whyte 603 (2017) with a FSA No.10 headset. All I can find out is thats its for 49/50 OD headtubes. I know on my older Voodoo I could run an external headset cup and fit tapered forks, can the same be done here? If not, do better 1+1/8th forks still exist new?
Posted : 04/08/2018 9:09 am
is it 44mm internal (I think the no. 10 is for 44mm internal), in that case its easy to fit tapered forks. Just need a new bottom bearing like a hope H
Posted : 04/08/2018 9:33 am
Nukeproof make an external cup version too for 44mm headtube and 1.5” steerer (at the bottom)
Option EX44-40 - B5
http://www.chainreactioncycles.com/mobile/nukeproof-mix-match-bottom-headset-cup/rp-prod124574
The only thing you need to be sure of is your headtube being deep enough to allow the cup to be inserted incase it taperes out from 44mm inside.
Posted : 04/08/2018 9:54 am
