headset bearing hel...
[Closed] headset bearing help needed please
[#3846828]
I have removed the headset bearings from my Stumpjumper expert carbon 2009 HT.
All internet docs etc.. suggest the bottom cup is 1.5", but mine seems to have a converter to 1 1/8", pic here -
[URL= http://img209.imageshack.us/img209/1619/img1815jn.jp g" target="_blank">http://img209.imageshack.us/img209/1619/img1815jn.jp g"/> [/IMG][/URL]
Uploaded with [URL= http://imageshack.us ]ImageShack.us[/URL]
I'd like to remove this and use a 52mm bearing, but it seems to be stuck firm. Before I hit it too hard and damage the frame, has anyone seen this before ? and if so can it be removed ?
Posted : 07/04/2012 11:56 am
You knock it out like any other headset cup however i havn't delt with one before so don't know what you will be left with {bare frame or 1.5 cup underneath} or maybe the 1 1/8th bit is sat inside the 1.5 cup.
Posted : 07/04/2012 10:50 pm
That cup will come out as your frame is Ment to take speshes own taper forks
But from memory you will need to get a headset from Spesh as there is more than just a bearing to go
Back in.
Posted : 08/04/2012 8:23 am
no joy, it is either stuck fast or forms part of the integrated headset.
Posted : 09/04/2012 8:47 am
Tapered tube should look tapered
1 1/8 top and 1 1/2 bottom
Adapter available to slieve it down to 1 1/8 part number something like 2009.9060
Think its nentioned in the 2010 stumpy pdf manual
Posted : 09/04/2012 8:55 pm
