Have I serviced my ...
[Closed] Have I serviced my forks correctly? (help!)
Just took the lowers off and lubricated the dust wiper seals. Put it all back together and when I compress the fork and release there is a high pitch squealing noise. This only happens when the rebound is set very slow.
I was cautious of over tightening the foot bolts, so could this be it?
(forks- fox float rlc fit 2012)
Many thanks
Posted : 05/02/2012 4:28 pm
 Taff
Have yoyu pinched the foam rings? I did that when I put the legs in forst. Secnd time fine and a squeak but soon stopped
Posted : 05/02/2012 4:43 pm
Have you put oil in the lowers before you fully reassembled?
Posted : 05/02/2012 4:58 pm
 Taff
I'm presuming he did it upside down. PS the squealing should be the footnuts.
Posted : 05/02/2012 5:06 pm
did you put the oil in the lower legs?
Posted : 05/02/2012 5:19 pm
Take them off again, check the foam rings and lube the seals. Cycle them while upside down once reasembled.
Posted : 05/02/2012 5:34 pm
Thanks guys
Taff- do you think I need to tighten them a little bit more (foot bolts)?
If I speed the rebound up the squealing goes away...
Any further thoughts??
Posted : 05/02/2012 5:43 pm
 Taff
It sounds more oil related. Did you do it upside down? If so how much oil did you lose and did you replace it? Tighten the foot nuts up a little but they don't need to be that tight.
Posted : 05/02/2012 8:38 pm
