Hanging your bike b...
[Closed] Hanging your bike by the rims - egg shaped cross max?
[#1811469]
I've seen a few storage solutions using nylon coated hooks to hang your bike on by the rims - can any wheeelbuilders out there give a view on this please. My understanding is the wheels strength is in the tension of the spokes where the hub 'hangs' in tension from the wheel - does hanging the bike by the rim point loaded on a hook have a detremental effect on your wheels - I don't fancy egg shaped boops for riding on. The bikes are likely to hang for a period of time (winter bike over summer and the like)
Posted : 18/07/2010 9:04 pm
My bikes all hang up like this and I've never seen the issue to which you refer.
If you're worried, why not "rotate" the wheel by a few degrees every couple of weeks?
Posted : 18/07/2010 9:05 pm
 nbt
I've done this for several years and never had any problems.
Posted : 18/07/2010 9:07 pm
Nahh. It won't happen. If you'd ever tried to destroy an old rim for a laff like I did once, you'd know how hard it is to even bend one! Weight of a bike is not even close to enough to bend a fully built wheel
Posted : 18/07/2010 9:11 pm
Never heard of such a problem occuring. The load is small really compaired to loads experienced during riding, plus its a tensile load on the spokes, and outside of the rim. It may over time mean you have to give the one or two of teh spokes a tighten due to creep but thats all.
No, they'll be fine, your hanging loads are tiny. Hang away. Only problems could come from fork oil hanging upside down, but its a small likelyhood of a small problem.
Posted : 18/07/2010 9:14 pm
OK. I've just been to the garage where I have 2 used rims hanging up, hung one off my fishing scales and swung on it. I maxed the scales out at 40lbs without even visibly flexing the rim. And that's a bare rim remember, not a fully built wheel! 🙂
Posted : 18/07/2010 9:16 pm
I set the hooks so the back wheel is just touching the ground.
Posted : 18/07/2010 9:27 pm
Luckily I've just proved that's pointless...!
Posted : 18/07/2010 9:36 pm
