Hand-built Carbon R...
[Closed] Hand-built Carbon Road Frame
[#5924266]
So Im keen for a project and as I can't find what i want in an off the shelf bike ive been thinking about making myself a carbon road frame.
I want it to be aerodynamic with internal cable routing and be able to run disk brakes. I guess that means 135mm rear dropout spacing. I would also like to be able to run larger tyres for cyclocross or just gravel roads as im in NZ and find i regularly could have more interesting rides if i could link up various sections via dirt roads.
I really like the look of the BMC TMR02 so something along those lines but disc compatible. Ive never built anything from carbon before so how realistic is this and would I end up with anything worth riding?
Im happy to run it with road geometry though as the off road wont be anything challenging. Also are large tyre clearances and aerodynamics at all compatible?!
Posted : 05/02/2014 10:55 pm
Anything is possible.
I would suggest you try and make a few small parts first and go from there. One thing I would think twice about is forks. The frame is actually easier than forks and the consequences of failure are also worse for forks IMO.
Posted : 05/02/2014 11:10 pm
Check out http://www.easycomposites.co.uk for advice, materials and courses.
Posted : 05/02/2014 11:33 pm
Agreed about the forks, I would be a lot more nervous riding on home-built forks than the frame.
What kind of parts would you suggest? Things like bottle cages?
Posted : 05/02/2014 11:52 pm
