Are my new forks wo...
[Closed] Are my new forks wonky?
 Euro
[#5924238]
Ordered a pair of Pikes and they arrived yesterday evening. No air in them from the box so i put in the recommended amount for my weight (85psi give or take), bounce up and down on them a few times and set them to the side to install on the bike this morning. After breakfast inspect my new toy and have a few more bounces only to discover they feel much softer than last night? Attached the pump to find they're sitting at around 40psi. That's odd, so i pump them up to 100 and leave them sitting untouched all day. Just checked again and they are soft and back to 40psi. Is it possible that i got some duds? I checked the returns policy and there is no issue with sending them back (although i will be out of pocket for postage) but just want to make sure i'm not wasting anyone's time.
Any ideas?
Posted : 05/02/2014 10:29 pm
 Dan
maybe check the air valve is not loose?
Posted : 05/02/2014 10:34 pm
Where are they from.?
Posted : 05/02/2014 10:41 pm
Re-fitting the shock pump will cause a drop in pressure, though that doesn't explain them feeling softer. maybe that's due to settling in/temperature?
Posted : 05/02/2014 11:10 pm
If they are faulty then the seller should refund postage.
Attach the pump, pump up and leave overnight with the pump still attached. Make sure there is a good seal. Might not be perfect but might give you an indication.
Posted : 05/02/2014 11:16 pm
refitting the pump will allow a tiny bit of air out, unless the air volume is very very tiny it won't account for a 60psi drop!
Check the valve.
Posted : 05/02/2014 11:18 pm
 Euro
Didn't have the correct tool again!! so bodged an air valve checker-outer from a fork of the eating variety. I've let the air out and gave the valve a check. They're pumped back to 100 again and i'll see how they seem in the morn. Fingers crossed. Cheers Dan
Please tell me this happens and this is what it is. I'd quite like to ride them to see what all the fuss is about 😀
Somewhere in Lancashire rob.
Mike and Andy. When i originally said this...
...i was lying a little bit 😳 . I coped a feel at around 2.35pm and they felt a bit softer. It was a lustful cop and not exactly scientific but I did notice her sag marking had gone from 10ish to around 15.
Posted : 05/02/2014 11:38 pm
 Euro
Flat again this morning 🙁 Looks like they are going back.
Posted : 06/02/2014 12:48 pm
Always disappointing to get a new toy and find it dosen't work. You should get your money back for postage if they are indeed wonky.
Posted : 06/02/2014 12:52 pm
You have checked the valve core haven't you? You can nip it up with some needle nosed pliers if it's loose or if it's broke get one out of an inner tube..
Posted : 06/02/2014 1:05 pm
^^ as above, try that first. the valve core looks like this:
You can grab the flat edges and turn clockwise to do up.
Or you could even remove it, and replace with a core from a schrader tube - I've done this in the past to fix a leaky valve.
Posted : 06/02/2014 1:18 pm
