halo spin doctor 6f...
[Closed] halo spin doctor 6f bearing fitting
Anyone got any advice? I can't for the life of me find any guides on their website. There seems to be no technical support at all.
Posted : 01/12/2015 2:45 pm
the way I get old bearings out of the hub is slide out the main axle which the cones thread onto, now the hub has a central tube spacer this will push up or down within the hub, with a punch you will now be able to punch the bearings out from the hub shell by knocking against the inner face of the bearing to drive them out.
- from Ison when I mailed them to ask the same thing. End caps / cones thread off, freehub comes off, bearings come out either side first. Really simple to do once you get a bit of movement in that central sleeve.
Posted : 01/12/2015 3:34 pm
Cheers, with your help I did it last night. It was the central sleave I was worried about, once I realised it was thin and could be pushed out of the way, I was fine tapping them out. Thanks for your help.
Posted : 02/12/2015 4:48 pm
