"Gravel" ...
[Closed] "Gravel" frameset with up to 42mm tyre clearance
Using Gravel for want of a better word, which disc frameset for slightly larger profile tyres than a traditional CX bike with all day riding comfy angles?
Posted : 24/03/2017 11:54 pm
Dare I suggest a VN Amazon? Just fitted some Nano 40s to mine today.
Posted : 25/03/2017 12:03 am
All City Macho King. 853 loveliness. Enjoying mine.
Posted : 25/03/2017 12:35 am
Saracen Hack will take 42c tyres
Posted : 25/03/2017 4:46 am
I've put 37 on my Kona jake- there's room to spare.
Posted : 25/03/2017 4:50 am
Surly Straggler...
Posted : 25/03/2017 6:37 am
My charge plug 5 came with 42mm tyres and it's fantastic
Posted : 25/03/2017 6:42 am
Pinnacle Arkose X (as a full bike).
Those Panaracer Gravelking SKs are wider than spec, 40mm version apparently comes in at ~43mm.
Posted : 25/03/2017 6:57 am
Sonder Camino Al. £50 off ATM too.
Posted : 25/03/2017 8:08 am
In great STW tradition! Could I recommend a Mason bokeh.
Posted : 25/03/2017 8:13 am
Mason Bokeh.
https://masoncycles.cc/products/bokeh-frameset
Must have posted that at same time Dickie !!
Posted : 25/03/2017 8:15 am
Rocket dog.... Budget would help?
Like others above I will recommend what I own 🙂
Genesis croix de fer. All day riding, tough as old boots comfy and can fit up to 45mm tyres. I currently run 40mm nano's with full guards (sks 50mm longboards).
Frameset is something like £350 if you look carefully (frame and fork).
Posted : 25/03/2017 8:16 am
 OCB
Peregrine (if you can find one), or a Vaya.
Mine are on 47 and 42 respectively, both very comfy all-day mixed condition bikes.
Posted : 25/03/2017 8:19 am
Peregrines are very pretty but I found the toe overlap really annoying.
I quite like the look of these as a Peregrine substitute:
[img] https://static1.squarespace.com/static/50a0aabce4b046b42953e2f5/t/560cb4ebe4b0d9a979c14892/1443673356917/SomaWolverine6 [/img]
Posted : 25/03/2017 8:33 am
On one pickenflick is worth considering.. Just sold a medium with hope wheelset sporting 45/40mm tyres ..
Too nice as a winter hack so I moved it on
Posted : 25/03/2017 9:13 am
^ mention of pickenflick makes me suggest the bish bash bosh - currently £499 at the DFS of cycling.
Posted : 25/03/2017 9:24 am
Evans are listing Arkose frameset at the mo. 40s fit fine in my 2015, 2017 has even better clearance.
Posted : 25/03/2017 9:25 am
I seen a bish bash bosh in Edinburgh last week in the orange/yellow.. It looked very nice 8)
Posted : 25/03/2017 9:26 am
Open U.P. for expensive niche factor.
Posted : 25/03/2017 9:38 am
I've been considering the Palnet-X XLA, bargain, but only 38mm clearance, which is annoying because the 'gravel version has more tyre clearance but a sloping top tube 🙁
Posted : 25/03/2017 11:16 am
Can fit 47mm tyres in my deeply uncool Raleigh Maverick Comp.
Posted : 25/03/2017 3:57 pm
Not forgetting Salsa Fargo if you're minted, Mango Point AR if skinted.
Posted : 25/03/2017 4:27 pm
Mango Point AR, bought a frame set last autumn and have run it over the winter, been a great bike with 40c clearance.
Posted : 25/03/2017 6:21 pm
Cotic escapade will take nanos in 42c iirc.
Posted : 25/03/2017 10:34 pm
Shand Stoater
Posted : 26/03/2017 7:01 am
I too have a change plug 5 ti and sometimes run bruce gordon rock n roads at 43c
Posted : 26/03/2017 8:47 am
Genesis Vagabond?
Posted : 26/03/2017 8:53 am
Those Arkoses look really good for the money. Does anybody know what the differences are between the 3, 3, and 4 apart from the price and the colour?
Posted : 26/03/2017 10:43 am
I seriously considered the Soma Wolverine until I cheaped out with a Charge Plug. They look amazing with a lot of nice details.
Posted : 26/03/2017 12:26 pm
 P20
Planet X Full Monty takes 40mm Nanos comfortably. Cotic Escapade? Or if Ritchey eventually release the Outback
Posted : 26/03/2017 1:06 pm
Posted : 26/03/2017 1:50 pm
Giant Revolt 1, very relaxed geometry & you can fit up to 50mm tyres, yes it does look a bit odd but a good allrounder.
Posted : 26/03/2017 2:58 pm
Another option...
Brother Cycles Kepler...
Posted : 26/03/2017 3:32 pm
If the yellow Giant Anyroad 1 was proper hydraulics and allowed wider tyres (it comes with 32c, not sure if 35c will fit), I'd be very tempted, love the frame's curves.
Posted : 26/03/2017 3:36 pm
doncorleoni ...
Any chance of some pics ?
I'm running 40mm nano's on my CdF (which rides like a dream) and thinking about fitting some mudguards for the next month or two.
Posted : 26/03/2017 4:17 pm
@[b]rOcKeTdOg[/b] any reason for the 42mm requirement, rather than 40mm?
Only, as evidenced by the multitude of suggestions in the replies, almost [i]all[/i] adventure-road/gravel/gnarmac bikes will take 700c 40mm. It could be said it's what defines the genre, and one of the things that differentiates them from CX bikes.
Posted : 26/03/2017 4:39 pm
No reason, 40mm would be sufficient. I'm just greedy
Posted : 26/03/2017 7:00 pm
Has the 2.1" clearance Marin Four Corners been mentioned yet?
Another I would be interested in, if it had proper hydraulics and a carbon fork.
Posted : 26/03/2017 7:10 pm
The spec? Am I missing something
I'd say that 42mm would be tight on a Croix de fer or 2016 Arkose. I'm not saying they'd touch the frame or forks but there would be very little clearance for mud. The arm of the FD might be an issue as well. This is an area where 1x11 or (1x10) has clear benefits
Posted : 26/03/2017 7:54 pm
The new Orro Gravel Terra Carbon comes out in April. They've upped the clearances compared to the alloy to allow 40mm tyres. Looking forward to seeing the finished frames, the protos have some nice features.
Posted : 26/03/2017 8:46 pm
 igm
My 2016 CAADX has 40mm G-Ones at the moment and plenty of tyre clearance to go with.
Not sure about the 2017 ones - they definitely played with the seat stays.
Posted : 26/03/2017 9:16 pm
 Sam
Running the excellent 42mm Cazaderos in my Kite disc and loving it.
Posted : 27/03/2017 12:13 am
How about this http://www.rodeo-labs.com/td2/
they say it takes "56mm front and 52mm rear at 700c"
Posted : 27/03/2017 6:00 am
Sutra LTD meets your requirements.
(And I will shortly have one for sale)
Posted : 27/03/2017 7:28 am
