Gpx favour???
[Closed] Gpx favour???
[#4325402]
Hi guys is there anyone out there with the ability to merge 2 gpx files. I was recording on strava and when stopped for lunch noticed that it was draining my phone battery more than Endomondo. So then changed to Endomondo. I would like if possible to have the two rides showing as one.
Perhaps I could email someone the exported gpx s ?
Cheers in advance x
Posted : 03/09/2012 7:39 am
They're just text files iirc, so you can stick 'em together using a text editor.
Try this
Posted : 03/09/2012 7:46 am
There's tool that do it for you, I'm sure this is the on I used.
http://www.gpsu.co.uk/descrip.html
Posted : 03/09/2012 7:50 am
Okay cheers guys ill keep on it ... I've tried but failed but will try try again
Posted : 03/09/2012 10:34 pm
If you want to email them to me, I'll have a go for you.
Posted : 03/09/2012 10:47 pm
Cheers buddy that's great I'll do it tomorrow if that's okay 🙂
Posted : 04/09/2012 10:26 pm
itsmygame - did you get the GPX file?
Posted : 08/09/2012 5:46 pm
If you're on Windows, Sports Tracks 3 is one I use for editing GPX. Not sure if it will merge them, but probably can.
Might be able to pull them into a Google map and export as one, not sure.
Posted : 08/09/2012 6:23 pm
Notepad appears to have done the trick. Just waiting for confirmation from the OP that he has the file.
Posted : 08/09/2012 6:34 pm
