not sure what's going on here. using Mac OSX 10.6.8.
went out today and did some filming with GoPro Hero+ which has been working great since purchased June 2016. seemed to be working ok out in the woods today but got home and only the first 3x clips out of about 40x i shot are there.
the 64gb SD card (EXFAT-formatted Lexar Professional microSDXC 633x 64GB UHS-I Flash Memory Card with USB 3.0 Adapter) shows 56GB used and 8gb available. there are only 3.2gb of files showing on the SD card. where is everything else??
filmed some more clips at home after the ride and all working fine.
emptied Trash with SD card in iMac and SD card now showing only 3gb used.
still not sure why GoPro didn't record while though. definitely beeped to announce filming then beeped 3x to announce finished filming.
any thoughts?
If you've put files in the trash, but. Not emptied it, they are still on your card. Start by putting the card in your machine, then empty the trash. The space should re-appear on your card.
Not sure about your missing clips however.
Ah, well... You got there faster than I could type.
