good tyres for wint...
[Closed] good tyres for winter?
[#903021]
Iam using Schwalbe Nobby Nic 26 x 2.25 but find them very slipy in the wet and with winter on the way i think i should change them two a better suited tyre. any ideas?
Posted : 28/09/2009 10:40 am
If you're after a proper mud tyre then I can recommend the Panaracer Trailraker. It's far from being an "all-rounder" but when it gets sloppy I've not had better. For a knobblie I don't find it too draggy either
Posted : 28/09/2009 10:42 am
the bonty mud x is good for all round use in mud but the trailraker is brilliant for winter only use
Posted : 28/09/2009 10:44 am
i use the bontrager mud x tyres, really grippy and don't clog up at all, they survived hit the north no problems last year! The only downside is that they are quite soft so wear fairly quickly
Posted : 28/09/2009 10:45 am
Trailrakers are relatively hard-wearing in my experience but I tend to put them on when I know I will need some help in the mud rather than have them on all winter
Posted : 28/09/2009 10:46 am
Depends what sort of terrain you are riding: Where I ride, in the North Downs, I find 2.35 Super Tacky High Rollers to be good, but then again I tend to avoid mud wherever possible.
You only need a mud tyre if you end up ploughing through the stuff for long periods which, I personally, can't think of anything worse.
Posted : 28/09/2009 10:49 am
my Schwalbe Nobby nics are rated 5 stars for grip in all conditions but thay just dont make the grade in the wet. has anyone found same problem or is it just me
Posted : 28/09/2009 10:51 am
ha ha, yeah whatever. Try riding in the White Peak in winter and then tell me that 😆 You don't have to be ankle-deep in mud to benefit from mud tyres
Posted : 28/09/2009 10:52 am
They're rather slidey certainly.
Another vote for Mud Xs, great winter tyre.
Posted : 28/09/2009 10:53 am
ha ha, yeah whatever. Try riding in the White Peak in winter and then tell me that You don't have to be ankle-deep in mud to benefit from mud tyres
That's why I said "depends what terrain you are riding" - read posts properly first, but actually I find high roller super tackies fine in all but thick mud, and that includes wet peaks trails.
Posted : 28/09/2009 11:03 am
Trailraker 2.1's for the winter here in Scotland. Great grip and traction but draggy if you have to do much road work
Posted : 28/09/2009 11:08 am
Swampthings in 2.1..... A pair is £28 posted off ebay...
Any mud tyre will be better in mud than an alrounder type tread, just pick whatever you can get at the right price.
Posted : 28/09/2009 11:10 am
mikey74, the curse of the internet strikes again and offence seems to have been taken where none was intended. I wasn't having a dig and I did read your post. I was pointing out to sapper that "mud tyres" don't have to be just for mud.
And yes, it would seem sensible that when choosing tyres, it "depends what sort of terrain you are riding". Now I am having a dig by the way 😉
Posted : 28/09/2009 11:13 am
Is it worth pointing out thet the Trailraker isnt Panaracers mud tyre?
They got one called a Fire mud for that, the Trailraker is a bit more of an allrounder with a slant on wet weather riding as it comes in slightly larger volume than the Fire Mud.
Posted : 28/09/2009 11:19 am
tinsy, no it isn't worth pointing it out. Don't confuse matters 😆
Posted : 28/09/2009 11:29 am
thaks for all your comments and help lots to think about now
Posted : 28/09/2009 11:52 am
