Glen Finglas.
[Closed] Glen Finglas.
[#7993209]
My other half wants to go here on Sunday and whilst I wouldn't make a special trip I thought it might be worth taking the bikes for me and the boy. A quick search suggests it might be quite hard work if it's been wet so given the rain over the last 24 hrs and possibly for a few more will it be worth taking the bikes and attempting to drag a 13 year old around?
Posted : 11/08/2016 8:59 am
The wet should not pose too much of an issue - there is a couple of little streams to cross and first bit is cut up by hydro scheme at present.
It's a bloody big climb...
Posted : 11/08/2016 9:07 am
Agree with Matt, pretty firm rocky/gravelly surface most of the way round - don't see the wet causing a problem.
The main climb is a proper climb for sure, only moderate length, but some [i]very[/i] steep sections.
Plenty of climbing outside the main climb too, as there are constant undulations.
Achievable for a fit 13yr old, but quite a challenge and likely to take a good part of the day.
Posted : 11/08/2016 9:20 am
Agree with the above
Do it anti clockwise.
Clockwise is very steep climb in places
Posted : 11/08/2016 9:24 am
Fitness won't be an issue for him but lack of trail centre type fun might be. But I'd quite like him to see that there's more to mountain biking than trail centres.
Posted : 11/08/2016 9:53 am
It's not the most inspiring area scenically either so it's not where I would choose to extoll the virtues of "natural" trails. It's sure a big climb for little reward. On the other hand, no day out in the hills can be considered a waste.
Posted : 11/08/2016 10:06 am
surface will be fine, and forecast suggests Saturday will be decent, so a nice day out. My 13 yr old son likes it, but he is a bit of a climbing freak 🙂 My 10 yr old wouldn't manage it. Anticlockwise is best, as Rich says
Posted : 11/08/2016 10:17 am
Finglas is a bit of an unending ascent - esp if you have a reluctant companion. You can add a bit of variety by going up the steep track form the Glen Finglas carpark nr Lendrick Lodge (poss a push in parts)which gives some high level singletrack to start and cuts out the steep road climb to the reservoir. Then at the end there is a little path goes in by the school and finish with some easy boardwalk out towards the car park again.
Paths are shown on this map
[url= http://www.thegreattrossachsforest.co.uk/assets/maps-guides/Glen-FinglasMap.pdf ]Gle Finglas[/url]
An alternative is to head through the forest via L Drunkie and do some of the singletrack around go ape. The return by the Menteith Hills – might be a bit over ambitious though.
Posted : 11/08/2016 2:46 pm
