Ghetto rim tape
[Closed] Ghetto rim tape
[#4679952]
Can I just use electrical insulation tape or is it worth buying proper rim tape?
Posted : 24/12/2012 11:47 am
I went for the proper stuff. Ive used PVC tape as an emergency rim tape (non ghetto) and always found it a bit rubbish. Too flexible and prone to stretching through spoke holes etc.
When you fit the proper stuff (and watch the stans vids on youtube for that) you get a feel of how the tape is good for the job.
Cheapest place I found was eBay
Posted : 24/12/2012 11:52 am
I've used insulating tape for years,never had an issue. Just go round 3 or 4 times.
Posted : 24/12/2012 11:57 am
For tooblessin I use this stuff.
Much cheaper than stans yellow tape and works just as well.
[url] http://www.ebay.co.uk/sch/sis.html?_kw=1+Roll+Of+STRONG+CROSSWEAVE+REINFORCED+TAPE+25mm+x+50M&_id=180875355845 [/url]
Posted : 24/12/2012 11:59 am
Roval tape is a tenner a roll and there must be enough on them for a dozen wheels if not more.
that crossweave looks good stu.
Posted : 24/12/2012 12:12 pm
Thanks folks, might get some of that crossweave stuff. kinda hoping I could do it today but I ain't going riding for a few days so it can wait!
thanks folks
Posted : 24/12/2012 12:18 pm
Gorilla Tape works great and is cheap and waterproof. Google Gorilla tape ghetto.
Posted : 24/12/2012 12:27 pm
Double wrap some insulation tape and ride your bike today? Even if it bothers you, it'll last a ride (it's lasted me about 4 years).
Posted : 24/12/2012 12:30 pm
Decent insulating tape is fine- if it pushes into the spoke holes significantly, you're just not using enough. But, it's a little easier to damage when changing tyres than Roval or Stans tape is.
Posted : 24/12/2012 10:13 pm
I've had the crossweave stuff peel off after sealant was added.
Posted : 24/12/2012 10:28 pm
+1 crossweave
get the rim properly clean and dry - sand, then clean with brake cleaner (and I dry with a blowtorch...) and it won't come unstuck. I've done road tubeless with it at 90psi (with no rimstrip) and had no issues.
Posted : 24/12/2012 10:49 pm
Another vote for the fibreglass crossweave stuff. Used for years, 1 roll has done about 10 wheels.
As Al says, it can peel at the edges, but this has only happened to me after years rather than months. It never leaked though.
Posted : 24/12/2012 10:53 pm
Interesting reggie.
Posted : 24/12/2012 10:59 pm
If you use the crossweave tape I linked to just put a tube in inflate it and leave it for a day.
That seals the tape end down a lot better and stops it lifting when you put the jizz in.
Posted : 26/12/2012 11:35 am
