Hi, I'd like to upgrade my drivetrain on my 2012 Latitude 10. So far I've determined that it's a 118mm octalink. Can anyone tell me whether the other dimension in the BB spec is 68 or 73?
Posted : 12/05/2015 1:44 pm
You could try and measure it, the newer models are 73mm (only need one drive side spacer)
Posted : 12/05/2015 1:53 pm
measure the width of the bottom bracket shell (frame only) it will be either 68mm or 73mm.
In my experience the best bet is to remove the crankset & bottom bracket, read the label on the BB so you make dead sure you replace like with like.
irrelevant on an octalink crankset
Posted : 12/05/2015 2:17 pm
Thanks for the info, am new to replacing bike parts, so the explanation is handy.
Guess I'll be buying a BB tool.
Gotta start somewhere...
Posted : 12/05/2015 7:31 pm
