Would a 44t chainring fit & clear the chainstays?? Or should I re-phrase: Given that the bikes come with a 32T as standard - Is there sufficient room to replace the 32T ring with something nearer 40t-44t?
Posted : 24/03/2014 9:10 pm
Wouldn't say so as it's on the middle tabs of a single ring chain set
Posted : 24/03/2014 9:47 pm
I was thinking of running a Surly fixed (135mm disc ) hub, which is apparently designed to run with a 50mm chainline ie. chainring in the outer position.
Posted : 24/03/2014 9:55 pm
A 40t should fit, I've got a 38t with plenty of room.
Posted : 24/03/2014 9:59 pm
Rik - MemberA 40t should fit, I've got a 38t with plenty of room.
Thanks Rik...Which fortitude do you have?
Posted : 26/03/2014 8:48 pm
