Can't see nowt on the website does anyone know if these lights/supplied o rings will run on 35mm dia bars?
I run them on 31.8, but they should stretch to 35 ok.
Nice one thought so how do you find em?
Based on the fact that my duo is a cracking lamp, I reckon 3 off them side by said will be awesome. Might need a big battery though
They're awesome.
I've swapped the outside lenses for a flood type instead of spot. No need for a helmet light with a Titan.
Ran one at the Puffer (on loan) and it was awesome!! On its lowest setting it ran the whole time (racing pairs) on the one battery (supplied with it) and lit up most of the highlands in the process. I'm not sure I would ever use the high setting for fear of starting a forest fire.
O-rings wise I found them pretty tight on normal diameter bars, but I think there were some larger ones in the box- the joys of using reps samples is they are never correct!
