Gear cable outers -...
[Closed] Gear cable outers - any specific recommendations?
[#2015594]
Need to replace the outers (and inners) for my gear cables. Previously, I;ve just used whatever I could lay my hands on, but I was wondering if there are any specifics that might give a bit more life with the usual mechanical neglect my MTB suffers.
OMITN
Posted : 22/09/2010 2:43 pm
shimano xtr off ebay for a little less than 20 quid for the full set. those little rubber things that it comes with seem to work a treat.
Posted : 22/09/2010 2:47 pm
nm
Posted : 22/09/2010 2:48 pm
Shimano - the outer is all the same, larger diameter stuff is slightly better if you can find it.
Not Dremelling my Soul frame...!
XTR off ebay sounds a good call. Anywhere specific?
Posted : 22/09/2010 2:49 pm
Think you can buy them from wilkinsons for like £1.50 a set, inner and outer.
These are bestest IMHO
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=24809
Posted : 22/09/2010 2:50 pm
xt outer - buy it per m from crc/wiggle
xtr inner from wiggle
works for me !
Posted : 22/09/2010 2:52 pm
28 quid for cables, binners - you're having a laff..!
They were fitted on my bike when I got it. They're ace! I've had them on for just under a year. My bike getrs some serious hammer and they're still as smooth shifting as the day i picked it up. I'd say thats worth 30 squid. You won't get that with shimano cables fella 🙂
Posted : 22/09/2010 2:55 pm
Ahh, go on!! No; I misread the title and thought you were asking for outer cable cutters.
I'd +1 for binners' suggestion. The first set of Gore (brake) cables I had on a bike lasted for over five years before I wrecked the inner sleeve in a spill. No cable system is as smooth and light in operation, and few will maintain their original performance for as long. Treat yourself...
Posted : 22/09/2010 3:02 pm
Tell you what, I buy them, you fit them AND warranty that they'll shift smoothly after 12 months worth of mud caking my bike... 😀
SP41 and teflon coated inners.
Posted : 22/09/2010 3:06 pm
I'll be round to fit them later fella. Now where did i put my hammer.....
Posted : 22/09/2010 3:11 pm
SP41/42 - and XTR ends and rubbers 🙂
Posted : 22/09/2010 3:15 pm
