Garmin log not show...
[Closed] Garmin log not showing below zero
 lump
Having a look over my record from today's ride and its not showing any temperature below zero. How do I change this to show the full range of temperatures ? ๐Ÿ™„
Posted : 16/01/2012 8:39 pm
Mine's the same.
Not sure you can change it.
Posted : 16/01/2012 8:41 pm
 lump
Meh ! thats a bit gash
Posted : 16/01/2012 9:43 pm
Obviously designed in the same place as Chris King rear hubs. Not designed to work below freezing. (btw my Garmin 800 does the same)
Posted : 16/01/2012 9:44 pm
I've not checked my track from yesterday to see if it recorded but my 500 was showing temps of -3 yesterday which was pretty much bang on.
Posted : 16/01/2012 10:24 pm
it doesn't seem to show it on the graph but it should show negative on the details panel (although all you get there is max, min and avg)
Posted : 16/01/2012 11:13 pm
 lump
So why have the graph and only show half the data ๐Ÿ™ Thanks guys, case closed I think.
Posted : 17/01/2012 7:22 am
Is this on the webpage?
Sounds liek a bug in the graph code to not show -ve numbers!
Can you change your units to Farenheit and see what happens?
Posted : 17/01/2012 8:52 am
 lump
Yes when changed the whole data is shown ๐Ÿ™‚
Posted : 17/01/2012 11:09 am
My Garmin 500 was showing -3 on sunday, and in garmin connect it was showing in the log as Farenheight. software update maybe?
Posted : 17/01/2012 11:11 am
 lump
Looks like its been fixed ๐Ÿ™‚
Posted : 14/02/2012 7:43 pm
