Garmin Edge questio...
[Closed] Garmin Edge question..
[#3851932]
I'm a bit unclear on this, can anybody help?
If I were to get a Garmin Edge 500, could I then plot routes on Tracklogs and export them to the Garmin?
I know that the Edge does not have mapping, but would it give me a "breadcrumb" line to follow?
Thinking that it may make exploring new areas easier. I'm not wanting to get anything bigger, so Edge800s and Satmaps are out.
Just fancy a tricked out cycle computer if it can also give some route guidance.
Posted : 09/04/2012 12:00 pm
Nope. No breadcrumb trail on the 500. It will record the rides for later analysis but won't give you a trail to follow whilst on your ride.
Posted : 09/04/2012 12:21 pm
I thought from the reviews that the 500 *does* give a breadcrumb trail in the same way as the Edge 205/305 does? eg. [url= ?imgmax=800]here[/url].
Assuming it does, the way you're proposing to use the Garmin stanley is the same way as I used to use my 205 (and now my 705) - ie. plot route out on Tracklogs and then follow breadcrumb trail...
Posted : 09/04/2012 12:39 pm
500 does breadcrumb trail (course) and it can be used fine for basic navigation
Posted : 09/04/2012 12:44 pm
Get the edge 500. I have one and it's immense. Use it on the stems on my road bike and it lives in my pack on the mtb. Pees all over the iPhone for gps type stuff.
Posted : 09/04/2012 12:48 pm
Ah!
So that picture shows exactly what I was hoping for.
That is an Edge 500, isn't it?
Any idea what format my "course" would need to be in?
Thanks again
Posted : 09/04/2012 12:50 pm
Try and get an older Edge 205 or 305. They do the breadcrumb route but you can also do 'proper' navigation where you plan a route (on computer) and it alerts you with a beep when you are approaching a waypoint and then shows you which way to turn (only downside is that it is limited to 100 waypoints max).
Posted : 09/04/2012 1:03 pm
stanley - Garmin crs format. GPSu or GPS Babel can convert to this for you, or use Tracklogs/www.gpsies.com for route planning and direct download
Posted : 09/04/2012 8:07 pm
 Jase
Garmin Connect or Bike Route Toaster.
Posted : 09/04/2012 8:12 pm
My 500 does breadcrumb so you can track back..
also you can use the course function to follow a track you have either ridden before or created in bikeroutetoaster.
works well used mine to navigate a whole lejog route (off major routes route)
it beeps when you go off course and can get it to beep at other points of courses created. It also alerts when you get back on course and when there is a sharp change in the course direction.
Posted : 09/04/2012 8:17 pm
