Fox shock tune tabl...
[Closed] Fox shock tune table?
[#3851928]
Ok so all shocks are set with a specific tune at point of sale, or when supplied with a bike, different size air chambers provide different spring curves.Smaller can = linear curve, big can = progressive curve? But I keep seeing references to shock tunes such as "b" (for a rocks box monarch) or "I" , I assume "m" is medium "L" is light "H" is high etc. where dose the boost tune come in?
I'm after replacing my x fusion shock on my specialised pitch comp with a second hand rp23boost valve shock.
any advise would be appreciated
Posted : 09/04/2012 11:58 am
Phone MOJO, best place for Fox help and advice.
Posted : 09/04/2012 1:09 pm
My trek ex8 2008 will only take the fox rp2, if I wanted to upgrade to the rp23 I'd have to change the rocker arm. So maybe your local specialised shop for info.
Posted : 09/04/2012 1:41 pm
Where'd you here that ricardo? The 2008 EX9 came with an RP23 as standard ([url= http://www.trekbikes.com/uk/en/bikes/2008/archive/fuelex9 ]Fuel EX9[/url]) and it's the same frame. The only real difference between the two shocks is that the RP23 has three Propedal settings to the RP2's one AFAIK
Posted : 09/04/2012 1:54 pm
