Garmin Edge Explore...
Garmin Edge Explore 2. Changing "Ride Type"
Can I change the Ride Type on my Edge Explore 2?
It has 3 profiles which I can rename, I understand other Garmin's have more and they can be added / deleted but the Explore is limited to the fixed 3.
There are Off Road, On Road and Indoor. Indoor is no use to me, can I change it to Off Road too?
If I can't change it will it still do the same job but just show up as the wrong thing when it syncs with Connect?
Cheers ๐Ÿ™‚
Posted : 19/09/2022 4:45 pm
Can I just rename the .FIT files that I've found??
Posted : 19/09/2022 4:55 pm
Just found the same issue. Bought for the bigger screen, thinking that I could repurpose the indoor setting as you can with some of their fancier devices. Seems that not.
Posted : 31/05/2025 10:23 am
I renamed the Off-Road to MTB on the device but it uploads to Strava as Gravel ride.ย  I don't think I can over ride that so I just edit it in Strava.
Posted : 31/05/2025 10:31 am
Posted by: masterdabber
You can set Activity Fix to automatically change any Gravel ride to Mountain Bike in Strava
https://activityfix.com/
Posted : 31/05/2025 12:28 pm
IIRC, you can rename the activity profiles if you want.
Also but I can't test now, I seem to remember that Indoor Rides don't capture GPS data, so it's bloody useless as an activity profile, no matter what you rename it as...
Posted : 31/05/2025 1:44 pm
 PJay
The 3 profiles thing is a limit imposed by Garmin presumably to mark the Explore down as a budget unit and encourage folk towards the more pricey units. It's a real shame though. People have been hoping the limit would be removed for years, so I assume now that we're stuck with it (unless there's a clever Connect IQ author out there who can hack it).
Posted by: vlad_the_invader
You can and the profile colour too, but that's it sadly (the ride type seems to be permanently stuck as 'Indoor'). Go to settings > activity profiles then select the profile then the 3 dot menu (top right).
The indoor profile functions as a full profile though. By default GPS is off but you can turn it back on and fully configure everything else. I suspect that that once it's synced it'll need editing in Connect itself to remove references to Indoors (as above, the ride type isn't editable).
Posted : 31/05/2025 5:00 pm
