Anyone have a Garmin Edge 500?
I currently have 4 different computers across 5 bikes and was thinking of replacing all these with 1 Garmin Edge 500.
Guessing I’d just need to buy some extra mounts for £8 each.
Do use 1 bike on the Turbo trainer but I understand that I can use the speed/cadence mount on the 500 for this.
Cheers for any comments.
I use one and really like it. You are correct about the speed/cadence and it's great on the turbo for looking at data afterwards. Mounts are a bit expensive, I need to purchase another one - it only comes with 2.
Cheers - Does it keep the signal under trees ok?
I've never had any problems with it losing signal so far. I keep it in my back pack on the bike I don't have any mount for yet, and it picks up the satellite through that. It can sometimes be slow to find a signal initally and I've had it hang on me a couple of times but nothing that's annoyed me too much.
fwiw, you ought to be able to use any ant+ speed/cadence/hr sensors (eg Bontrager etc - a lot of them look like they're the same thing, rebadged - a speed or cadence sensor is about £20 each)
http://www.thisisant.com/
compatibility chart:
http://www.thisisant.com/modules/mod_product-directory.php
From what I read on a road forum in the last few days, if you've got the speed sensor fitted then it may well default to that, if it loses lock - not sure whether that's applicable to the 705, 500, or both..I may have the link squirreled away...
(I'd been looking at a Bontrager Node 1 or 2 for a cyclocomputer - on a recumbent, so wireless range/tidy wiring's an issue, hence ant+ gear - so now I'm wondering how useful the GPS mapping of a 705 might be. Tho' I've seen one thread rumour that a revised version might arrive at the end of the year. Hmmm...)
There's a decent review of the 500 here - additional q+a at the bottom:
http://www.dcrainmaker.com/2009/11/garmin-edge-500-in-depth-review.html
Supposedly the Oregon 400t and 300 support speed/cadence sensors, but curiously Garmin don't list them in their cycling products - I've yet to check what the differences are between them and the 500/705.
That is a really good review, thanks for the link.
Interesting to see that you cannot set the HR zones on the unit itself.
+1 like mine a lot. Came with two mounts. So easy to swap it around.
Glad to be of service 🙂 - mebbe you have already, but it might be worth looking through some of the roadie forums, I suspect they're rather more common there, given the power measurement angle
eg:
http://www.kingstonwheelers.co.uk/kwccforum/viewtopic.php?t=3987&highlight=500
The Garmin forums are probably worth a look, don't need to register either:
https://forums.garmin.com/forumdisplay.php?f=219
Thanks.
Just seen they are launching it in grey/black any time now so will pop down my LBS and see if they can get that in the bundle.
Got the grey/black bundle from LBS - [url= http://www.philcorleycycles.co.uk/ ]Phil Corley Cycles[/url]
Used it for the 1st time today and its great, like the way it shows the grade of each hill.
Just about to customize the data I view.
Looking at data afterwards is cool too.
