Garmin edge 305 bat...
[Closed] Garmin edge 305 battery change
 2002
[#4778852]
My 305 battery seems to be going as the run time has dropped right off and part of me would like a Edge 500 but part of me likes fixing things and I have watched a video about changing the battery and I wondered if any one has tried it and had any luck doing so or is the 500 a better unit all round.
Posted : 21/01/2013 8:32 pm
Yep - same problem with my Edge 705. The run time was down to less than 2hrs & it was running out of power partway through a ride.
I googled it; watched the u-Tube clips on how to replace the battery; & bought 2 from the web - pos from China - I think..
I needed a v small torx screwdriver to get into the unit (which luckily I had) and it was all straight forward. Turned it back on and all works well and it now lasts much longer. I haven't tested how long yet but certainly 3.5hrs+. I have ran mine for 6+hrs on the original battery & hope it will do the same although I think re-chargeables are less good in the cold! Change the battery - its easy!
Posted : 21/01/2013 8:45 pm
my Garmin 705 froze last week. popped the back off, disconnected the battery, and left it alone for 30 minutes, then put it back together.
hey Presto, up and running no problem.
Posted : 21/01/2013 9:08 pm
