Garmin Dakota bike ...
[Closed] Garmin Dakota bike mount - rubbish...
First ride out with a new Dakota gps and bike mount, the Dakota came flying off the mount twice within the first few minutes of semi-rough stuff. Not happy, considering returning the whole lot for a refund. Anyone else had a similar issue, or alternatively find the mount works ok? Could just be a problem with my mount and/or gps back I guess. Cheers.
Posted : 25/04/2010 3:01 pm
Had my Etrex come off the handlebar mount twice, both times a different part had worked loose. Both cost me 67quid for the unit to be repaired / replaced by Garmin.
Posted : 25/04/2010 3:07 pm
Me too, had an etrex come off recently and get run over. The Etrex mounts are quite well made to. I've seen reviews complaining about the Dakota / Oregon ones. I know make sure I wrap the lanyard around the bars as well.
Posted : 25/04/2010 6:13 pm
it seems to be a weakness across the range, i have edge mounts on 4 bikes and they have all broken
Posted : 25/04/2010 6:17 pm
Ta for the heads up. Just bought two mounts but not yet used them.
Posted : 25/04/2010 6:26 pm
I've done thousands of miles with an Oregon on the bars - no problems at all.
Posted : 25/04/2010 6:29 pm
Have to say, my Dakota is solid on the mount, its quite difficult to get off when I want to, definetly doesn't feel like it'll fall off..
Posted : 25/04/2010 6:37 pm
Mine seems to be fine, I do always wrap the lanyard round just in case tho.
Posted : 25/04/2010 6:44 pm
Will have to get a lanyard on mine when I get it back from repair / replacement again.
Posted : 25/04/2010 9:39 pm
Well, this has been interesting reading.
For years I have had a basic E-trex and never had a problem. However, it has now detached itself from two different bike mounts.
I am guilty of turning bikes upside down so potentially mount has worn slightly. Don't feel happy with it on the bars at all now, which kind of defeats the object! I guess it could possibly be the actual back of the gps.
Posted : 25/04/2010 9:42 pm
garmin geko has been fine for me for over 5 years now
Posted : 25/04/2010 9:43 pm
Thanks for the feedback all, looks like the reliability of these things is variable to say the least. Tbh I haven't been super impressed with the Dakota anyway, & have decided to return it under distance selling malarky & wait for the next gen of "rugged" gps.
Posted : 25/04/2010 9:44 pm
My anchient etrex seems to be flawless, presumeably as they got smaller they got more flimsy?
Posted : 25/04/2010 9:46 pm
Ironically, I never had a problem with my Edge mount, and over quite a few years of Legend use, it only bailed a couple of times.
Posted : 25/04/2010 9:49 pm
I've done a lot of bouncy rocky Dartmoor rides and my edge 305 on the new mount works well (the original mount was broken when I bought it off ebAy, and the new one I bought is noticeably beefier)
Posted : 25/04/2010 10:01 pm
Are you mounting it on the bar or the stem? Mines on the stem, which probably adds a bit of ridgidity to the mount.
Posted : 25/04/2010 10:57 pm
This the mount that cable ties onto the handlebars? My datoka has never fallen off, in fact its a bit of a struggle to unclip the thing at the end of every ride.
I did initially use the lanyard to tie it to the handlebars as well just in case but this has long since been removed.
Posted : 26/04/2010 6:37 am
I did a couple of years with an Edge & it never came off once, switched to a Forerunner 310xt which I leave on my wrist, saves taking it off for cafe stops etc & I run with it lots too.
Posted : 26/04/2010 7:05 am
I use the below mount from RAM for my eTrex. Very solid and has never come off. I also attatch the lanyard to the stem so even if it did come out of the mount it wouldn't go flying off [under a car wheel?!]
Maybe they do one for the Dakota?
Posted : 26/04/2010 7:22 am
 MSP
I mount mine on the toptube rather than the stem, seems more protected, and is less distracting.
Posted : 26/04/2010 7:30 am
same with my dakota too...its come off a few times up the peaks over rocky stuff even though its clipped in.....well lucky last time as it fell off i assumed it was a rock just hitting up, my mate behind me saw it fly off into a gulley of water, luckily wasnt deep and semi waterproof....so cautious using it around rocky stuff now, that it distracts me when going downhill ๐Ÿ™
Posted : 26/04/2010 8:12 am
