Garmin 605 question
[Closed] Garmin 605 question
 SOAP
[#3203574]
Do I
A: throw it against the wall
B: Smash it with a hammer
C: Repeatedly drive over it
any ideas would be great
Posted : 02/10/2011 5:33 pm
I had a similar problem to this...It turned to to be the USB lead! You'll probably have another cable lying around. An old phone cable or a PS3 controller lead is what I used.
Posted : 02/10/2011 5:37 pm
 SOAP
just plugged the car Garmin in and I get the same result!
thanks
Posted : 02/10/2011 6:00 pm
Can you still view the device as a mass storage drive under My Computer?
Also right click on the 'unknown device' go on properties or details or some such, see if a driver is associated to it and delete it. If not try and find the Garmin drivers on the computer for your device and remove them. After that plug the device in and hopefully windows will see a new device and install it.
Can't be more precise as I'm on phone, and no guarantee it'll work but worth a try
HTH
Posted : 02/10/2011 6:32 pm
 SOAP
cannot see it under My Computer but the unit is charging.
just un installed the Drivers and its still the same 🙁
Posted : 02/10/2011 6:42 pm
Does the unit turn on?
Could try a hard reset...with device off hold power and mode button until unit comes on and asks if your sure (or something along those lines) you'll lose your history on the device history screen but it will still be present in the devices mass storage so you can import them into Garmin Connect separately if needed.
HTH
Posted : 02/10/2011 7:00 pm
 SOAP
reinstalled drivers from garmin,and it still turns on tried hard reset and still the same.
just brought a £1.99 lead of ebay so will see if that works
Posted : 02/10/2011 7:08 pm
Well assuming you've tried all the other USB ports on the computer, hopefully a new cable will work. Have you another computer you can try it on in the mean time.
Posted : 02/10/2011 7:27 pm
 SOAP
£1.99 lead and its fixed 🙂
Posted : 04/10/2011 7:26 pm
